critterkllr
I have a Gibson GA-5 guitar amp that I've been slowly working on over the past year. It was in pretty pour condition and missing a lot, so it needed some work. I'd like to try replacing the bridged t tone stack with the tone switch that is used on the second channel of a Matchless DC30. The treble knob would be replaced by a the cut circuit found in Vox amps (as well as the Matchless).
My plan is to remove the tone stack starting at C3 and to reattached it at pin 7 of V1B. I'd be implementing the 6 pole switch from the Matchless schematic, as well as the 1M pot and the 470K to ground following it. Whether or not I'll need the bright cap will depend on how it sounds. Is there something else that I would need to take into account? For example, does this circuit require a specific output impedance from an EF86 to work correctly? Am I fine using a 12AY7? My knowledge on these things doesn't touch what you guys know.
Some mods that I've already done to the amp:
Removed R3 and jumped C1. Changed the cathode resistors to 1.5K and bypass caps to 25uF. I'm using a 12AY7 instead of a 12AU7. I've given the amp a cap job and lowered some of the filtering. I also added a switchable negative feedback loop. I've tried modding the tone stack by adding 100K between C4 and ground, as well as changing some of the cap values, but I'm just not getting along with it.
