moamps
Abbey, thanks for assistance. You started to drawing blueprints, that's something new
R6 change - increasing the current of the left CCS, to get slightly better working point of FET when VDS increases.
R7 change - keeping the current thru diodes at same level when PS voltage is higher
R8 replacing to CCS - CCS has for AC very high impedance, it helps to get higher headroom
C3 change - lowering LF cutoff point
R9 change - it loads the output so it should be high, just enough to keep C3 - pol DC wise on ground
warpie said:Could you please elaborate a bit? Why these changes are needed?
