Whistle Rock Audio ML12 preamp BUILD/HELP thread!
Well here it is. ML12 PSU Gerbers. I Recommend ordering pcb with 2oz copper traces. This is intended for open source project. Not for commercial use.
5-5-24 Updated BOM and silkscreen on Gerbers to reflect alternate U4. TL783 high voltage regulator adjustable output range of 1.25v to 125v. This part is better suited to supply 48 phantom volts compared to the standard LM317 which only is adjustable from 1.2v to 37v. Instead I recommend using the TI LM317HV which is capable of supplying 1.5 A or more currents over a 1.25-V to 57-V output voltage range. If using TL783 *Omit* D8* & C21*.
  • ML12 PSU BOM.txt
    3.4 KB
  • ML12 PSU Gerbers.zip
    290 KB
    592.4 KB
    439.3 KB
    547.4 KB
    356.9 KB
    869.7 KB
Updated silkscreen for " alternate U4" part TL783 high voltage regulator. Corrected BOM. Check above. Note U4 should be the high voltage variant the LM317HV.
Dang! Great work! I'm just about a couple months too late as I bought the 2448 PSU kit from five fish.
Btw anyone have a legit source for the BC560C?
Hello,
Does anyone know, if the Haufe RK240 is a suitable mic input transformer and what zobel network it needs in the ML12?
Thank you very much!
Best regards,
Jan
Another question,
I have a spare output transformer from a 1073 preamp. Its primaries and secondaries are fixed in series wiring, so having 200:600.
Does someone know if it would work in an API 312 built? I could choose from 2520, 990 and App992 DOAs.
Would I need the zobel network consisting of resistor R64 and capacitor C9 on the secondary of the neve LO116 output transformer, like in the Neve preamp?
I know that I could test it myself, but maybe someone tried before and I don´t have to reinvent the wheel.
Best regards,
Jan
