bruno2000
horvitz said:Actually not so bad, I think. As Dan said, if you carefully remove the front plate from the continuous rotation switch, you'll find the stop holes hiding behind and it looks like you can slide a pin in there (a bit of resistor leg fits well). Not surprised at all that GH would do this so that they can use the same parts on all of their switches. Here is a picture of exactly that:
The switches I want to modify for "stopped" don't have the metal ring insert with the holes, but they do have the pin "receptacles" molded into the plastic piece that houses the detent hardware.
I'm going to try a pin in the plastic, and see if it holds up.
Thanks for the photos!
Bruno2000
