Motown Direct Amplifier-inspired Preamp?
Unless we hear from CJ otherwise, this is the final schematic:-
best
The closed circuit 1/4” output jack will effectively short out the secondary of the output transformer if nothing is plugged into it (if wired as shown).
Perhaps you intended to have pin 2 of the XLR connected to the switched connection and not pin 3?
Mark
I think that is a stereo jack (tip and sleeve--ring not shown) and not a switched mono jack.
Unless the schematic is "properly" drawn out to show what the designer's actual intent is, you can only -- surmise -- what the current schematic is actually showing. DaveP will either need to update his schematic to electrically show what his intent really is or, he will just need to offer an explanation of what his current schematic is actually conveying. But.....I also get your point as well!!!
did some tests with a pot in place of the feedback resistor, here are some numbers>
Output Voltage taken at output cap, not xfmr secondary, voltages are P-P values
Input: 100 mv 1 KC
Output: 10 V Gain: 100 F/B Resistance: 240K
Output: 5 V Gain: 50 F/B Resistance: 91K
Output: 3.6 V Gain: 36 F/B Resistance 56K
Output: 1.0 V Gain: 10 F/B Resistance 14K
So due to some changes in grid resistors and the tube type, the F/B resistor value for a gain of 50 (34 db) is now 91K, at least on the amp that i built, this includes the 20 pf cap across the resistor.
also, with the new grid resistors, the sq wave response seems to have gotten better to the point to where the grid stopper on stage 2 is no longer needed.
i am going to use a pot to adjust the gain of this circuit from 50 to 120 so it matches the vol pot on my other amp.
Here are some numbers for a clipping test with various levels of negative feedback, volts P-P, 1 KC Sine Wave>
NFB Resistor: 240K Clipping at 1.6 V Input Output Voltage at cap: 120 V Gain: 75
NFB Resistor: 91k Clipping at 2.7 V Input Output Voltage at cap: 110 V Gain: 40
NFB Resistor: 56K Clipping at 3.5 V Input Output Voltage at cap: 100 V Gain: 28.5
NFB Resistor: 15K Clipping at 5.0 V Input Output Voltage at cap: 50 V Gain: 10
so gain drops at clipping level except when the resistor is at 15K which is when the most feedback voltage is applied to stage 1.
This has been a very educational thread, CJ has shown how you go about developing a circuit and curing its snags on the bench. Over the years I have been on this forum, it has been disappointing to see so many guys wanting easy answers instead of working things out for themselves. Solving problems by experiment gives you confidence and cuts through the BS that you find everywhere online nowadays. Groupdiy is a great source of ideas that can help you solve the problems yourself, all you have to do is listen.......
best
Thanks, I did have a lot if help from other people, and due to the suggestion of using a smaller grid resistor, I found a bad solder joint on a 1 meg on grid #2, the resistor was loose in the socket pin, I am wondering if this was the cause of the excessive ringing at 10KC, I might unsolder that resistor to see what the effects are.
Funny that I made some changes and then undid them which led back to pretty much the original schematic,
Check this out, they make Motown stickers, I got one coming in from Redbubble for the front, put a little clear coat on it,
https://www.redbubble.com/i/sticker...p8I7xe0zDYEMrZ5vjbkaAidMEALw_wcB&gclsrc=aw.ds
  • stickers,black,print-2024-04-07_fd27681a-c2a8-41fe-98bc-df821e7576fe,2d2d2d.jpeg
    54.1 KB
