MS Matrix inside Audio Development mixer
Help Support GroupDIY:
timtom
Member
Berlin, Germany
Hey everybody,
I want to add a MS matrix inside my AD mixer to use only 2 channels with my stereo M/S mic instead of 3 channels, for recording straight to a Nagra tapemachine. I was planning the following:
- Inserting the Matrix after the EQ section.
- make it switchable.
I used this schematic and designed this board.
The mixer is giving +/-12V.
How should the ground of the power supply and the audio be connected ? (I connected them all together)
I powered up a prototype board and I get very loud noise at 20/30hz.
timtom
Member
Berlin, Germany
The +/-12V should be clean enough as they are coming directly from the mixer.
The 20-30hz are also present without the nagra tape machine.
I'll add the 100nf caps and check again.
abbey road d enfer
Moderator
Marcelland
Hey everybody,
You have a streo mic that uses 3 channels?
The rule is "Ground follows signal", so you should connect it at the insert send/return ground.
How have you evaluated the frequency? have you measured it with an oscilloscope?
If it's really that low, it's a sign of "motorboating", a problem that's usually due to inadequate rail decoupling.
