Trust me - Aubort knew what he was doing."Maybe stereo" is what happens if you use the wrong mics, or blend it wrong, or place it wrong, or.....I could go on, but it's wasted. Most people never drive it enough to get the training wheels off, and are blaming their own lack of technique when they blame MS.
Others have used the term 'Maybe Stereo'; the Aubort quote I'm familiar with is that he referred to coincident technique in general as "fat mono". He did all his (on-location Classical) work monitoring on headphones, and that's just what coincident (and MS especially) sounds like on phones.The late Marc Aubort of NYC' "Elite Recordings," once said, "M/S stands for 'Maybe Stereo'." And I agree with him. I've used it quite often to good results but I always feel "dirty" after --- ; >)
I have been involved with quite a few large organ recital recordings and what has worked out well for me is just using a ROYER SF-12 stereo ribbon microphone placed on a 16-foot high mic-stand, along with two Audio-Technica cardioid condenser mics placed about 10-feet away on either side from the main pipes, but facing towards them. The SF-12's and the Audio-Technica's were all recorded onto their own tracks of a 24-track recorder.Hi chaps and chapesses,
I have a query on mic placement. But first, a bit of background. I wish to record organ recitals, and at the same time, to gain experience in mic techniques. So I propose to use a single tall stand (max height around 6m) placed roughly centrally with a large mic mounting bar, about 650mm long. At its centre point I propose to put a Blumlein pair comprising two active Marantz ribbon mics. Next, on each side of the ribbon pair, I want to place an ORTF pair of Samson SDC pencil mics, for which I have matched-pair capsules, both omni and cardioid. My last pair, I want to be MS. I propose to use a CAD LDC hyper-cardioid (can't remember the model No.) for the M mic, and a t.bone RB 500 ribbon with in-line FET preamp as the S. All 6 mics will be input to a Zoom H6 with phantom power available on all channels, including the dual-input adapter which replaces the H6's native mics. The thing is though, in order to preserve a manageable weight balance on the stereo bar, I propose to put the M mic on one side of the existing mics and the S mic on the other. Frontal sound (i.e. the organ) will arrive simultaneously to both the M and the S mics (not that the S will pick up much frontal sound anyway) but the ambient sound will arrive at the S at a different moment from the M - one side slightly early, the other side, late. As every example of MS mic placement I've ever seen shows the M and the S mics coincident, I wondered if there would be any unforseen phase problems I might have overlooked.
Thank you in anticipation for any words of wisdom.
Best regards, Tony.
MONO bass for an organ recording? - no thanks . . .Perhaps not well known: ORTF plus an Omni mic in center with LP1 set at 200 Hz mixed into the middle..
Works fine for organ recordings.
BR MicUlli
It depends..MONO bass for an organ recording? - no thanks . . .
And yes phase/time delay differences below 200 are audible.
It's exactly below 200 where L/R time differences are so important to producing in the listening room that sensation of envelopment that one gets hearing an organ in a large church/cathedral.
True, I overstated a bit.It depends..
This technique is NOT mono bass. If the omni signal is mixed carefully the differences are subtile. I admit that the result is also dependant on the recepient situation (room, speakers or even headphones). However it is worth to give it a try..
In former analog vinyl times it was a must to avoid phase diffs between LR channels at low frequencies. A lot of recordings sounded very convenient and pleasant. Higher harmonics stay locatable nevertheless..
They used specially designed equalisers to filter, sum to mono and roll off the bassTrue, I overstated a bit.
All Decca Classical LPs were recorded with huge L/R phase diferences; Decca Tree, plus outriggers 10s of feet apart - somehow they were able to cut the LPs so most players could play them. Maybe the LP mastering summed below 60Hz or so? IDK.
Which I would hope were not used for the CD remasters.They used specially designed equalisers to filter, sum to mono and roll off the bass
In most cases the CD remasters were done from the original 2 track tape masters pre vinyl mastering, these would be what would have been sent to the record cutting plant - all final EQ compression/limiting and level matching adjustments, to fit album side times, would be done in the cutting studio including of course the RIAA cut/boost. Some remasters were done by digitising the multitrack tapes and remixing and mastering for CD.Which I would hope were not used for the CD remasters.
I'm also a fan of this ORTF + Omni method. The omni is there for a bit of support and focus. I think of it like parallel mix processing.Perhaps not well known: ORTF plus an Omni mic in center with LP1 set at 200 Hz mixed into the middle..
BR MicUlli
This is more done when comparing arrays for a specific location - often there are constraints in mic placement locations. You have to select according to the location, mic choice for an array is also a major factor and obviously the same mics are not all suitable for all arrays.When A-B-C comparing mic arrays, it doesn't make any sense to put them in the same location at all
I have done a few tests with M/S being initially sceptical and one of these was to set up the mics and walk around them to see how well the image tracked actual position of the voice - it was pretty close to placement position including 90deg hard left and hard right. I used a pair of AKG414’s for this one. The problem I find with M/S is it seems mainly suited to smaller spaces with grouping around rather than in front of the mics but if set up properly for the right situation it works really well.I feel like MS doesn't really represent what is actually on the left and right of center, it just presents the room sound in a weird sort of stereo.
Can I ask what headphones you prefer? I’ve been loving some of the planar headphones, like the HEDDphone Two or Audeze, but they are open-back, so no isolation.This is why I like to use well isolated headphones (mine go down to 5Hz also and I set the overall level to match room levels)
MS has nothing to do with noise.I always found MS too noisy for quiet passages.
