Hi to all!
I had very busy time for last months, the time for road from Haifa to Tel Aviv
takes about hour and half each side, and freelancer's day at local hi-tech is never limited.
The most time-sucking project is finished, I did some cash for making fun, audio and have some free time.
VERY sorry about leaving support threads abandoned.
Bugagaga, Bender is here again!
Now, let's try to figure out and fix .
Internal wiring and 1/2 - BA283 stuffing... hope, it is clear:
http://ij-audio.com/downloads/pult2010_MS_wiring.pdf
All this IMHO is possible to figure out from schematics.
Please note:
Ed Anderson's EA-10468 transformers, connected backward, are shown at this drawing as input trannies.
For 31267, VTB9046, VTB9071, etc, every needed info is printed right at MS/Bypass PCB, on connectors:
PRI+/-, SEC1+/-, SEC2+/-. The rest: RTFM (transformer's datasheet).
Primary half's are connected in series (one connection at transformer).
Zobel networks were tested with 31267 and EA-10468.
The values shown in BOM are used not to "over-cut" the transformer's transient response.
Of course, other trannies can be used, just keep in mind, they should have symmetric windings for secondary's.
Output transformer's I used are VTB9049 and EA-1166.
Inductors.
I used local supplier for inductors, and added VTB9054 package on PCB which one of guys shared with me.
I never tested the EQ with 9054, as I wrote.
So...here we go.
I will order 30 inductors this week, they will be ready within a 10-15 days; a part of them will go for my use,
the rest will be offered for low as possible cost at web store, it comes up with all possible worst case conversions about USD35/pair.
The PCB, BTW, shows inductor's values,
And of course, you can use your DIY inductors as well.
Take a core, wire, make 100 turns, measure, calculate Al, here we go...at all, this is DIY.
Please note the dot and right placing, if use my inductors:
Well... I hope, the .pdf file will spot some light on mysterious sorcery; the rest of docs can be found here:
