I have this power adaptor with selectable voltage from 3, 6, 7.5, 9, 12 and I decided to measure it and the voltage from the adaptor is off by alot and seems to behave weird.
3v = 12v
7.5v = 10v
12v = 16v
Similar to this.
For example first time I plugged it in, it was set at 9v but it was giving out 12v on the multimeter.
Then I turned it off and then changed the settings to other voltage values and it would sometimes stay at 12v for all the values.
Does the power adaptor store electricity on the-same voltage and I have to give it some time to reset and go to the new voltage?
Is it normal for these power adaptors to have readings that are way off, like 3v = 6v, 7.5v =12v, 12v = 16v?
I measured my other multi-voltage power adaptors and they behave the-same.
Thanks.
3v = 12v
7.5v = 10v
12v = 16v
Similar to this.
Thanks.
