Multiple SDC capsules for lower noise.
Interesting idea.
The audio signals will be correlated, but the noise will be uncorrelated.
This would theoretically mean: 2 capsules reduce the noise by 3 dB.
You would need four capsules to reduce the noise by 6 dB.
But unfortunately practice isn't always the same as theory...
It might be worth an experiment.
In a way, that's what AudioTechnica did with AT5040. I believe Line Audio uses capsules with built-in FET so i guess it doesn't count. Overdo it, and you might get THD issues.
