mabell313 said:Paul678 said:mabell313 said:Good stuff! Now I am sure not to screw it up! Thank you Paul. Very informative. I have been searching 603 capsule mods to no avail. Well, nothing clearly stating what to do. CAD 1200 search did the trick! 1000~4700pf is a good range for the caps you added. The caps are absent on the Chinese SDC's but are usually present on the LDC or the SDC that look like a LDC. THe caps go across R30 & R40 on the MXL 603 schematic which is the same as any of the other Chinese SDC's. I hope this is clear to you as it is early and am nursing a pretty nasty hangover. Mmm, German beer.........
Well, just as a disclaimer, no matter how informed you may be, you can always STILL screw
a mic up if you are not careful! The diaphragm is delicate, and you can easily lose the two plastic
spacer rings if you breathe too hard! Also, it's VERY easy to leave dust or tiny particles of dirt
between the diaphragm and the back plate (you'll see the mylar get deformed). In fact, I had to
disassemble and re-assemble 3 times before the mylar was clean and flat.
Yes, you can put the caps in parallel with R30 and R40, but since they are virtually in series, you
can also simply use one cap of 1/2 the value, across both resistors (across the two bases of Q30 and Q40).
It's amazing to tone-form a microphone! It's almost like modifying an instrument!
Indeed! Even if I screw the capsules up too bad the mics are dirt cheap. If I break it I'll just replace it. Don't you mean double(x2) the capacitance?
No, you are thinking two resistors in series.
Two capacitors in series is like two parallel resistors: if they are the same value, the equivalent
is 1/2 the value of one cap.
Let us know how your mod goes......
