MXL V63M how to open the case
Rick H
Member
Honduras
My V63M after 22 years has become noisy. I suspect bad caps. I live in Honduras and ordering a kit of parts is very expensive to ship here but I can buy parts locally. My first question is: How do I open the mic case to expose the circuit board?
Welcome Rick,
Yes, describe the noises (or record them) so that we can help you better. I suspect that your microphone has problems in the high impedance area or in the microphone capsule itself due to moisture (and dust?).
First I must learn how to open the mic. I have instructions for that now. I suspect capacitors only by hunch. With 20 years old electronics caps are the first thing to look at. While I have the mic apart I will look for dust, clean up the circuit board, look at solder joints. I am well experienced with electronics repairs but this is the first microphone I have serviced.
The noise is a low level continuous noise, but random pops which make the microphone unusable. When I leave the mic powered for several hours the pops decrease in rate and volume (as if electrolytics are re-forming). The pops are the bigger issue.
I now have the mic disassembled.
the symptoms you describe match my diagnosis very well, this is not an unknown problem that you describe. I suggest you replace the capsule with another (working capsule) or install a ca. 60pF capacitor as a “dummy capsule”. If the problem is then gone, you know what is going on. An intensive cleaning of the high impedance area with 99% alcohol would also not be wrong, the impurities / moisture are usually not visible to the eye.
Sometimes it also helps to place the microphone in a dry, warm place for a some days...
Thanks for the tip. I cleaned the cartridge and exposed side of the PCB in the area of the preamp. The pops have gone away, There is some low level noise left even with the cartridge replaces with a 68 pF cap. The mic is now in a warm place overnight. I will leave it there another day.
I am impressed by the amount of crud remaining on low cost circuit boards.
Could I carefully use 70% alcolohol instead? I would apply it to a soft toothbrush or a one of my special static-free brushes on the workbench, opposed to soaking or spraying the board.
[Someday, I will buy a dedicated board cleaning solution ... but, shoot, that would cost real money and cut into my bourbon and chocolate budget.]
Thanks - James
Thanks - James
I have had really bad experiences with those cheapo Chinese mics over the years: MXL & SP etc.
The residue left after soldering is obscene, at the same time if you have to produce a 100 units a day to get your pay cheque, you can't pay attention to detail and cleanliness.
I found 90 degrees disinfecting Alcohol at my local Pharmacy.
That alcohol and a tooth brush works really well.
Warning! : keep it away from Styrene caps and the membrane of your Mic Capsule.
M
    991.6 KB
A long time ago, a recognized expert advised me to use only very high-percentage types of alcohol for such cleaning jobs, as they leave no residue when they evaporate. Every percent of water could be a problem. I don't know how important that is, but I've stuck to it and have done well so far.
Until recently, I always bought this at the local pharmacy, where I was always strictly questioned what I was going to do with it and the quantity was limited to 200ml. Really! 😬
But now I've found this 1L bottle for around €9, which lasts forever at the local (Obi) hardware store.
This should be taken seriously, some plastics don't particularly like high-percantage alcohol either. Caution: very flammable, evaporates quite quickly at room temperature.
    732.6 KB
HAAAAAA!!! 🤣🤣🤣
"I'll drink it with my GDIY Alkie friends!!!" 😅
Should have been your reply!
M
Cheers lads!🥃🥃🥳, but I rather had the impression that the pharmacist suspected me of building something really dangerous with it.:cool:
I have no idea what you can do with it, I wasn't that active in chemistry lessons back then...
Thanks, guys - I will lay in some full bore, Hi-Test, Leaded type - without compromising quality or strength. :)
I will also think of some smart Alec reply for when the vendor asks me what I need it for. By way of analogy, when I am seeking a hidden ham radio transmitter, I tell inquisitive, curious bystanders we are "Licensed by the FCC to search and locate Non-Ionizing Radiation in the environment." I have had some odd looking loop antennas in m back yard which have drawn the attention of curious neighbors ... to whom I explain they are special "bat deflectors which mess with bats' internal radar so they steer clear of our back yard whilst looking for prey." :) Yep .... THIS, they believe! If you tell a fib, tell a whooper! :)
I will cook up some similar silliness for why I need full strength alcohol! :) // James
