MXR Auophaser - psu voltage?
Pierrelegere
Active member
Berlin
Hi, I am just about to rack a MXR autophase module. The pinout is labeled on the unit,
but not the voltage. Is it 15V? Or 24? Thanks for your help! Best,
Peter
I had to fix one of these for someone once.  There are tantalum bead capacitors in the circuit.  try swapping them out !
Also the control voltage in & out need to be linked
the mxr autoXXXXXXx range have been covered a bit before !  see here
http://www.groupdiy.com/index.php?topic=16348.0
