maxwall
- Joined
- Nov 17, 2004
- Messages
- 1,134
Have a early 80's MXR omni 180 guitar effects rack and pedal board on the bench trying to fixup for a friend, can anyone donate test info or schematics. This has the BBD chips SAD4096 and SAD1024a. Taking a shot it might be something other than the BBD chips. Maybe a bad op amp , comparator or other linear IC. The PSU is at 15 vdc no issues, no obvious shorts in the circuit. The unit passes dry signal but the pedal board switching is not activating all LED's on the rack unit when the pedal board switches are exercised. The LED's on the pedal board do work ok all mechanicals switches are ok. Tested pots & mechanical switches on the rack front panel. All 1/4" input and output jacks are functional and clean. Tested all Electros and Tantalums for ESR and low resistance. Tested and reset all trimmers. The result are no effects heard at any stage. Ultimately if the BBD chips are bad then this unit is electronic waste. There is a service manual online for $20 but I'm going to hold out on that option.
The effects chain as follows : Comp - Distortion - EQ - Delay - Flanger/CH , External Loop with gain control
Here is a list of IC components for Omni 180 :
Opamps : LM1458(x12) , RC4558P(x2), TL072P
Other IC's : NE571N, NE5045N , CA3280E, CA4053BE, CA4013B, LM339N
Transistors : 2N5088 , 2N4126
Reticon Bucket Brigade Chips (BBD) : SAD4096 x1 ( delay ) , SAD1024a x1 ( flanger CH)
Also , looking for a top & bottom snapshot of the pcb for the DIY Hamptone HVTP2 tube preamp kit that was released way back in 2004 . Wanted to build one of these but Hamptone discontinued it. Wanted to do a point to point version as a project. Apparently a lot of these were sold at the time they were offered in kit form. Hamptone offers no support or info on this tube preamp kit. All current website support has broken links and incomplete info. Not sure if a official build guide with schematic was ever released with the kit. I already have the Tape Op article with schematic but I prefer something from the actual build guide as I suspect they may not be like for like.
