deuce42 said:Silvas - what do you think of the Edcors?
I like them in mine. I had some Sowters in and in a blind test with myself decided I liked the edcors slightly more!!!
veermaster said:Very nice especially with the sensitivity control on the front and the stepped pots !
You say meters are Nissei?
Couldn´t find them on their site:
http://www.nissei.com.cn/productVM.html
Or is this the wrong Nissei?
Cheers, Emre
RedNoise said:Hi Silvas !
GLU for sure!About the frontpannel painting , did you manage it by yourself?Love it!
Silvas said:I left the "limiter response" control on the front. I always wanted a LA2A like this, and i made the right choice. When fully CCW, it is like "flat". When turning CCW, it gets less sensitive to low frequencies, thus preventing exessive pumping on bass and other bass-heavy instruments. What an useful feature ! (at least for me). These aren´t stepped controls but standard 1M alpha pots.
mjproc said:Silvas said:I left the "limiter response" control on the front. I always wanted a LA2A like this, and i made the right choice. When fully CCW, it is like "flat". When turning CCW, it gets less sensitive to low frequencies, thus preventing exessive pumping on bass and other bass-heavy instruments. What an useful feature ! (at least for me). These aren´t stepped controls but standard 1M alpha pots.
Did you use linear pots for this?
livingnote said:Nice - this one shot right past me - LA2A is certainly on the build list...sometime...
I can see you now with that drill eating away at those meter holes![]()
electrochronic said:Silva
Sometimes you can use a hole saw( with dill bit centering fixture ) and drill press or 1/2" shank heavy duty hand drill for those meter holes, then go over them to smooth out some roughness. The hole will generally stay fairly round and the centering fixture kepp the hole saw from jumping around on the surface.
overall great results.
Where did you find those rotary switches for the 100K stepped attenuators ? Those look like ones I've seen on
Ebay , I think. If there are what I think they are , I like the switching torque on those, you don't have to twist them too hard. They use these on the impedance matching switches used in wall junction box home theatre attenuators.
