chrispbass
Great work Ian, really interesting reading your analysis
Best
Chris
Best
Chris
ruffrecords said:Prototype tube FET PCbs arrived in the post today. I will build one up and check I can get dc out of the side chain first.
ChrisPbass said:Thanks Ian![]()
This is a very well known technique. In the schematics I have posted this is achieved by the pair of 1M resistors, one feeding the control voltage and the other the input signal to the FET gate.pvision said:Just re-read this thread, Ian. There's something in the back of mind about FET compressors applying signal as well as the control voltage to the FET to reduce distortion
When I used 1176s every day on vocals & bass I tended to use 4:1 virtually all the time. Higher ratios were strictly for effect. So you could omit some complexity here and have 4:1 and ∞:1 (like the MXR PWM limiter) or not have a ratio control at all (like the Orban 418A)
The Orban 418A might be a good source of ideas. Bob Orban seems to have been very particular in his designs and the PCB is a work of art. There's a complete schematic, layout, block diagram & functional description in the manual
Nick Froome
pucho812 said:Why not go the other direction and have a variable ratio?
