I visually re-inspected all points in the PI and EL84 pins…all looks good.
New tests:
Removed EL84’s, tested all pins to ground.
Pin 2 measures 510K to ground on both sockets. This is my grid leak resistors.
Pin 3 is 225R, and that is because i recently added a 100R to the 125R to see if that helped anything. Maybe that’s a bit high in the long run, so will lower. But this has the cathode bias sitting at 12V instead of 9.5V.
Pins 7 and 9, the hot DC pins, each have very high 1-2M impedance and slowly sinking impedance due to the capacitors.
Then I put the EL84’s back in, and I snipped the connections from the pair of bypass caps coming from the PI, added a pair of 470k resistors in series coming out from each cap, connected this balanced signal to a TRS input on audio interface, and powered everything up as normal and measured DC post caps just to see if there is some leakage coming through the bypass caps that had nothing to do with the EL84’s. There may be a little bit but i don’t know enough about cap technology to say it’s a problem… they both rise up to around 20mV during power-up surging, but settle back down quickly to around 5mV to 12mV. Both caps do this. And they remain there for a while. I thought maybe that would be enough leakage to feed the grid and cause a surging DC situation, but even with the connection from PI to EL84’s completely severed, the one EL84 still red plates. And when it red plates, interestingly these detached cap outputs settled down a bit further to almost 0. I think one side settled lower than the other, in fact in went negative maybe -0.005, and the other cap remained positive around 0.005. These are brand new MKT1813 caps. Is that sufficient? I am guessing that the reduction here during red plating is due to the overall B+ collapsing during red plating.
But again, this test means the EL84 red plating is not directly related to any tiny DC output from the PI. Maybe it’s not helping and maybe it’s slightly exacerbating it, but it’s not the root cause. And yes, the 470k grid leak resistors were still in place when i ran this EL84 test that red plated. The only thing detached from the ELI84’s was the audio input lead post the bypass caps. My currently existing 41k grid stoppers were just floating mid air.
I also listened to the audio of the PI output. Just like the last time i did this, the sound seems excellent. Mind you this time i had 470K resistors feeding a 15k audio input, so this made quite the audio level drop due to voltage divider there, so I had to turn up the preamp and output volume of the amp to get a good level. Just like last time, it was pretty much perfect until it does eventually start clipping in the PI itself but this in theory is WAY beyond the point where the EL84’s would be driving with their amazing drive sound so it is not even close to the same clipping level. The normal clipping happens even at low volumes.
The only thing i can possibly conclude right now is that not only is one of my old tubes bad, one of my new “matched pair” tubes is ALSO bad, just by some bad stroke of luck. Like can a tube cause it’s own DC surging/leaking?
But even using both “cold” tubes as a pair, although it stabilizes the situation and nothing red plates, it does NOT solve the early clipping level….
As I mentioned this yesterday, i hooked up the one OLD cold tube and the one NEW cold tube, and by that i mean the tube from each pair that didn’t ever red plate, and the system becomes stable and no tube red plates even after sitting for several minutes (red plating has been occurring around 1.5 minutes i would estimate). So….
The PI distortion is still there. But this has me wondering, maybe i have two usable tubes on hand now, and maybe i need to adjust the circuit that somehow sucks by design? Like if I have two tubes that i can pop in the EL84 sockets and the DC situation doesn’t red plate, I’m one step closer to this functioning. However, what would then be adjusted to stop the PI from clipping at low levels?
Or maybe i just need to abandon this PI design and change it to a long tailed pair or something else? I hear cathodyne PI’s are known for clipping ugly. But my audio test proves that the cathodyne early clipping is caused by the load the EL84’s are putting on it, or something like that.
Here is the latest schematic and i think i got GroupDiy’s platform to insert it visually now..
