I wonder on what grounds he would have demonstrated that... I'd be curious to examine his arguments. Unfortunately I'm not clairvoyant...ruffrecords said:David Manley would have agreed with that assertion but used a lot more expletives in its expression.
abbey road d enfer said:I wonder on what grounds he would have demonstrated that... I'd be curious to examine his arguments. Unfortunately I'm not clairvoyant...
That is to be expected, less gain and a little les THD.lassoharp said:With the cathodes unbypassed you lose about 5-6db of gain and the signal sounds a little skinnier and cleaner.
In fact noise should not increase as much as gain, so S/N ratio ends up better.Bypass and you get the reverse of all the previous parameters. The noise increases slightly as you'd expect with the increase in gain but it's not a deal breaker by any stretch.
