Mysterious mixing console
Some capacitor date codes indicate on 2006.
But not sure . .also I attached previously mentioned board with some markings on it .
    1.9 MB
Thank you again, everyone, for your input. Although we didn't figure out who made it, I still managed to build a power supply for it, and it runs beautifully. It has extremely low noise, tons of gain when necessary, and the sound quality is excellent. The transformers add a nice weight to the sound, and I couldn't be happier with the result.
    3.6 MB
It is a PM500 console from the German DIY magazine Elrad mid of the 80s, designed by our esteemed colleague Gerhard Haas (RIP 2020) from Experience Electronics (Germany).
Really, they had such high-quality projects in the Elrad? Amazing! There is a certain similarity. Do you have the complete original article?
Gerhard Haas was a nice man, I spoke to him several times on the phone, he was very informative and eager to provide information. RIP.
Thank you so much! I can't believe you actually found it. I had almost lost hope of figuring out what it was. I really appreciate the information, you’re a legend !
Isn't it a bit strange that the phantom power resistors are connected after the attenuator?
I'm not sure if it's strange , but it seems like parts of the circuit diagram are missing in that schematic. , when I switch the line input, the phantom power automatically turns off and won't engage. So probably that’s why.
  • 74516586839__2FA9238D-D614-4A13-AAB8-DBA59C05B44C.MOV
    508.6 KB
What happens is that the phantom power is almost shorted through two 100 ohm resistors, causing a dissipation in each phantom resistor of (48/6900) * 48 ~ 330 mW. So 660 mW 'wasted'.
I can imagine why they wanted a low source impedance when in the line mode, but I would have done this differently.
Should you ever need any of these ancient and undocumented PCBs to be "Reverse-Engineered" so you can have "New/Old" PCBs fabricated.....let me know, OK??? I have done PCB "Reverse-Engineering" projects for old 1974 API mixing consoles and 1979 U.S. fighter jet PCBs. Just sayin'.....
Mic > Phantom , Line > No Phantom And Attenuator
Exactly my thought too. You do not want significant dc reaching a line input. With the 100 ohm resistor my calculator says the dc is reduced to 70uV.
But I agree, it is wasteful of power. Better to put the mic/line switch on the transformer side and have the pad permanently connect to the line input.
The input is for Mic and Line , look at Bild 1 on page 3...
I suspect there is a different modification in my channel strips
, as it seems there are two input transformers on the board. It’s likely that one transformer is dedicated to the line input, while the other is for the mic input.
    12.6 MB
