Allright, took a while but i'm back on track
I got a good soldering iron, got some desoldering braid, and i practiced a few times on some old boards, de soldering was pretty easy, soldering itself is also not that difficult, sometimes i get alil "bump" but its so damn small like the other "proffesionall" soldering joints so i dont worry bout it.
ok I ordered a few Film caps (Mkp Whatever that means ;D), here is a picture, damn those are kinda Big hehe
Now I need to get some wires to Hook it up, I saw how you did it tchgtr, 1 Questions left
1: If the new Cap "touch" one another Cap is this dangerous? because of the Voltage or heat it produces?? Cause I want to place it where u placed it right in front of the Output Transformator housing, cause on the Backside there's the Tube..and it almost touch it when I place it there so I want to stick with the Idea to place it on the Front/Top side, also i saw your wires touch the Elco on your picture but this should be no problem.. I just worry bout Heat and Voltage when I see all those Caps..
