Hand soldering processes
Even for hand soldering, the processing differences between tin lead and lead free must be considered. The solder tip must be adjusted to the higher temperatures required. For lead free solders, the EMPF found that the solder tip temperature needed to be set between 343°C / 650°F and 371°C / 700°F as opposed to 315°C / 599°F for tin lead solders. Temperatures higher than 398°C / 750°F were considered unnecessary for most hand soldering applications.
Because of the higher processing temperatures, components and boards must be baked out prior to soldering. Studies show that components increase moisture sensitivity by 2 levels, based on IPC J-STD-020 guidelines. Bake out insures that moisture is driven out prior to processing. Entrapped moisture is the root cause of component and board delamination and popcorning. The EMPF determined that boards should be preheated between 100°C and 125°C in order to reduce thermal shock and prevent pad lifting.
Operators must be re-trained to support lead free solders. EMPF staff have trained operators in the nuances associated with lead free hand soldering. Lead free solders require a longer dwell time – the time the soldering iron is in contact with the hardware. The longer dwell time promotes adequate heat transfer.
Due to the higher soldering temperature, the soldering iron needs to be removed more quickly for lead free solders, otherwise icicles will form. The size and frequency of solder icicles is dependent upon the alloy used and the temperature setting of the soldering iron.
The higher soldering temperature also requires that the soldering iron must be kept clean and coated with the solder alloy. Lead free solders are more sensitive to the effects of a dirty soldering iron. The higher soldering temperatures can cause oxidation of the soldering iron tip if not cleaned and coated. In addition, the EMPF recommends that different soldering irons be reserved for lead free and tin lead soldering. If the same soldering iron must be used for both, the EMPF recommends that different soldering tips be used for each type. Separate tips will prevent lead contamination of lead free components and solders.
A completed lead free solder joint has a grainy, dull finish. The bright surface associated with tin lead solders is not a material characteristic of lead free solders. Because of this difference, operators and inspectors need to adjust their visual inspection criteria. The IPC has changed the visual inspection criteria of J-STD-001 and IPC-A-610 to take this into account.
Once these adjustments were implemented, the electronics manufacturers audited by the EMPF were determined to have the capabilities to perform lead free hand soldering.
