Ptownkid said:Wow...that's crazy, it's a clone of Mnats pcb...
3nity said:Seems like this is your first project huh??
it would be fairly simple if you ask the guy you bought it from for more info!
you need the switching boards, if there are any or just do some more work here!
gemini86 said:do you have the boards for the pushbutton switches? if no, get them from hairball.
kazper said:I'd say download the manual from JBL, verify it to the schematic and by then you will know how to wire it. for the most part id does look like a modified Gyraf/Mnats Rev J pcb layout. That said if you verfy the project you should have no problem making it go.
Build quality it looks fine, just not a well known project from here.
good luck. BTW the logo on the pcb looks familiar..
gemini86 said:I still don't think it's an mnats...at least not a rev J... The output transistor should have the alternate holes for different pinouts (517/518 vs 139/140) and the input and output transformers should be on opposite sides of the board. Here's a Rev j overlay attached.
