Your drawing is basically right. It just needs a few tweaks.
XLR pin 1 goes directly to chassis at the XLR and nowhere else. This applies to both the input and the output. Pin 1 is not a signal pin is is a screen pin. So the connection you have from pin 1 of the input XLR to the transformer screen should be deleted. Any shields connected to pin one should not be connected at the other end of the cable. Balanced cable screens should never be connected to anything other than chassis.
You need a separate wire from 0V on the PSU direct to chassis at the same place the mains is earthed.
If you go to the DIY page of my web site:
https://www.customtubeconsoles.com/diy
ans scroll down to the Power folder, in there you will find a document called Grounding101.pdf which explains this.
