Hello,
I have a Neumann M149 microphone which started to cut the sound when singing into it.
The cable had a dodgy connector which was replaced, and the cable carefully re-soldered at both ends and tested.
The PSU was also tested when connected to the microphone and all the voltages are perfectly up to spec.
I did a sound sample that I'm attaching to this post showing the problem of the microphone.
Could you please have a listen and let me know what you think the problem might be?
Thank you so much
Thank you so much
