micaddict
Super, Dennis!
Henk
Henk
micaddict said:You say she's a dynamic vocalist. By definition that would mean not just loud.
I'd love to hear her do some quieter stuff, too.
On this mic, of course!![]()
fredbasement said:Hey fellow forum-members,
I'm in need of some help from people that have built or have experience with the the M49-B-Version:
So how do I start without being boring ;D
First some info about my build and how I got around some bugs:
1) Heater Voltage business: I didn't have a 1G-Ohm-Pot at hand so I installed a DC/DC step-down (buck) converter to get the 5,7V Heater Voltage, which seems to works fine
2) Plate current business: With b+ at 120V when R10 was still a fixed 100k I had only 37V on the plate (so 120V-38V/100k =0,83mA and I thought pretty close) But everybody in the thread said it had to be around 50V. so I installed a variable Resistor to get the 50V, but it doesn't do me any good, because when I have 50V on the Plate i have only 30k on R10 which would result in 120V-50V/30k = 2,3mA which seems a little too high. So how did you guys balance this out?
3) Capsule: I bought a k47 replica of micandmod but it doesn't spit out any signal... If I measure the three terminals where the capsule is supposed to be connected against ground I have 5V on the Front Diaphragm, 5V on the Back-Plate and (depending on the polarization) 0V/2.5V/4.5V on the Back Diaphragm. Dany said the values look fine, but how can a condenser work without any electric potential between diaphragm and back-plate... i don't get this... and how do I find out what voltages actually end up on the membranes? I know everyone talks about the 120V/60V/0V- Polarization Voltage not taking into account the giant resistors in between the supply and the capsule.... so what voltages need to be on the membranes and looking at the m49b schematic: from where does the capsule get its ground?
thanks in advance for your time and input... I really want to use this mic and it seems i'm pretty close....
hope someone can help me... you can also send a pm at: info@fhon
thanks again,
Frederik
fredbasement said:hey dan, you're right - it disapeared. I made such a foolish mistake, that i was too embarressed to keep the post up there for everyone to see. ;D I'll post again, when I figured out where I'm at... greetz, Frederik
fredbasement said:OMG Dany! ;D
it was quite a journey but I have a working Mic now!
but it's not the M49(b). after fixing my initial misktake of wiring the fgrid to the cathode/gnd floating pin instead of the s2a pin my voltages were all over the place and didn't look nearly as nice as before. I have literally spent hours of trial and error getting it right but the filament bias is a real pain to put it nicely. maybe I should have been a little worried when you wrote something about "required creative bending". I guess my creativeness wasn't up to the task... anyway after being all frustrated I went back here to find the foxresearch m49(b) update and I thought hey that's great I'll do the modification. well after this the pcb just shorted out and I didn't even have a solid B+ anymore. so with the b-version all screwed up I went to a local electronics shop, got some new parts for stuffing the M49(c) and literally before the last resistor my soldering station died.... but even with that short delay (I go an awesome new soldering station) the c-Version was done that evening:
B+ = 120V
Polarization = 118V / 58V / 0V
H+ = 5,8V
Plate = 48V
Cathode = 1,4V
with R7 @ 2262k (0,707mA)
(dany: how could I get up to 0,73mA?)
it works without hum or noise or anything and sounds rich and tasty.I will be able to really say something about the sound when I get to the studio in a couple of days, because I cannot really hear much at the bench. but I'll keep you updated about the sound.
but to end the little tale about non-professional soldering-enthusiasts wanting to build the M49(b): "JUST DON'T!". the M49(c) gives you much less headaches and you'll have a functioning mic much sooner. It is the safer route!
alright you guys. thanks so much for reading.
PS: Dany, any of those 47-FET pcbs lying around???![]()
have a great day...
oh and here are some building notes i destilled, so to anybody that does not want to read the whole thread.
hope it helps.
Frederik
build notes:
Connection For AMI T49 to PcB
TRFO to Mic PCB
A- 4
B-3
C-1
D-2
5840 tube:
For Converting the 5840 Tube to a Triode:
Tie pin 7-5 Togheter.
Do not use Pin 4 or Pin 8.
B+ = 115V
Plate = 53V
Drop across 100k (plate resistor)
= 115-53 = 62V Voltage drop across 100k
that means the tube running at .62ma
We want about 45V on the plate to get to
the specified 0.7ma then
R7 = 2.2K (m49c)
R7 = 22K? (m49b)
m49C:
self bias / heater isolated from cathode
R7 (cathode resistor) = 2.2K elevating cathode from gnd
bypass cap to prevent negative feedback (NFB)
10uf (20uF / 25uF) cathode bypass cap is recommended with the 5840 tube.
(series standard diode for heater supply (just before the connector to drop the 6.3V heater down to about 5.6V for underheating)
proper bias = 1.6V (cathode voltage)
plate resistance: 103.5K / cathode resistance: 2.279K
m49B:
fixed bias / cathode voltage ref'd to h+
H+ needs filtering to prevent ac in grid voltagen (Vgk)
With 1M ohm pot in power supply
set it to (4.4V-6 ) = 1.6V bias with 52V plate as results
adjusting plate voltage to 50V with B+ at 120V
plus 100K plate resistor leads to 0.7ma plate current in filament biased (b)
Power supply:
passive choke filtering.
full recitfied B+ and heater.
120V-6V after warmup.
polarization voltage in cardiod should be exactely half the B+ voltage
minus a hair for current limiting resistor inside the psu. (ca. 58V)
B+ to 120V then adjust plate voltage to 50V to get 0.7ma plate current
calibrate plate current not the bias. 58-59V on the R6-R7 node.
M49 Power Supply transformer hook-up to main P.S.B.
Yellow & Red / Black & Orange To P.S.B.
X-1-2 and X-1-1 = where the Choke Goes
X-5-1 and X-5-2 = where the heater trimpot goes
5840 correct wiring:
pin 1 = through the board to fgrid
pin 2 = connect to K turret
pin 3 = connect to HG turret
pin 4 =cut
pin 5 + 7 = connect to A turret
pin 6 = connect to H+ turret
pin 8 = cut off
Nyquist said:Hey guys. Have had a bit more time to muck around with this build. I have added a 100K lin pot for a fully variable pattern (removed the 3 position switch). I have also been mucking around with the bias both by ear, scope and using my multimeter. Simply dialling in 120V,50V exactly and exactly 1.6v bias gave the best results both sonically and headroom wise. I have ordered a bunch of different 5840 tubes to find the quietest and nicest sounding option. At the moment I'm running a Sylvania USA made 5840w. It's a bit noisy, but sounds okay.
I'd love to get a AC701K for it but they are stupid money. Last but not least I removed C6. This opened the mic up added more air and seemed to balance the whole shooting match a bit better.
Clip
https://cdn.groupbuilder.com/groupdiy/u/39511/58d028199430b.wav
