monsieurpr
Member
- Joined
- Dec 23, 2020
- Messages
- 13
Hello.
I have a Neumann N61v (preamp removed) power supply unit for M582 or CMV563 microphones.
I would like to change the electrolytic capacitors to protect the transformer and microphone in case they would fail in the future.
I have a few questions for which I couldn't find the answer in the existing threads on the forum.
Maybe someone will be able to give advice.
I intend to replace the old 22µF high voltage capacitors with new ones with the same capacitance as the polarization of the capsule draws very little current.
For the low voltage capacitors that filter the tube heating, I wonder whether it would be a good idea to increase the value of the 1000µF to give more current stability and make the voltage rise more slowly which may be better for the filament.
Modern capacitors are so compact that 15000µF would fit in the same volume!
However,
- Can it bring any noise improvement?
- And can it be detrimental? Indeed, increasing the value will increase the inrush current at start. Could it kill the diodes? The original GY101 diodes are rated 100mA, and so is the fuse.
I am not so concerned about the transformer because it looks oversized (in comparison with what you find in modern PSUs).
Other question (more for anode polarization capacitors): the old electrolytic capacitors have a metalic casing connected to ground (casing is the - pole).
Is it just for conveniency for the mechanical concept or does it bring any shielding against transformer electromagnetic leakages?
In the past I converted chinese PSUs to 5.8V and 120V voltages but never could totally get rid of the transformer hum even after using a better quality transformer from Toroidy.
So, should I shield new capacitors using aluminum foil ? 1000µF capacitor can be found with casing connected to - pole (EPCOS B41789) but I could find the equivalent for 22µF.
Thank you very much.
However,
