NOON
Today I picked up a Neumann NKMa power supply. It's an older one with the stablyte (or whatever they were called, seem to be NiCad batteries) and they have leaked badly, leading to some pretty nasty corrosion all through the unit. I will be restoring it, so will post photos etc as I go.
Two questions to start with. As this is an older unit and seems fairly original, does anyone want proper photos or other documentation of what components were used, wiring layout etc? Any specifics let me know.
Does anyone out there have experience with these units and have any tips on restoration back to working order, once I get the corrosion under control? Would you recommend fitting new NICad cells or is there a better way to do it now? (e.g. is NIMH a better way to go or some other battery technology, or even supercapacitors)
Back story is I picked up a KM56 a few years ago without a PSU and designed my own, which has been working well. The NKMa is not 'necessary' but it will be nice to pair the mic up with an original. So I'm not in any hurry to get it going and don't mind taking a bit longer to do it properly, especially if there is some kind of 'magic sauce' to be had from e.g. using batteries for the heater reg rather than the modern regulator I am using in my PSU design.
