Neumann pv76n schematic (23pin connector pinout)
jakobz
Active member
Hi
Does anyone know where to find documentation for the Neumann pv76n. I have learned that except from the filter section it is mostly similar to the pv76. But the Pv76 uses a 13 pin connector and the Pv76n uses a 23 pin connector, so the power and input/output connections does naturally not match. I found a thread mentioning the schematic (Neumann PV76 modification) but the attachments are gone.
I think you are looking for a PV76n schematic? With a 23 pin connector? The pinout of the 23 pin connector should be similar to other 23 pin modules. I'm attaching files for a Neumann HT75. It is stereo so the audio connections may be different but the power connections are likely the same.
