patrick chen New member Joined Aug 19, 2023 Messages 3 Nov 24, 2023 #1 Does anyone having the T20 pin spec? Thanks
gyraf Well-known member Staff member GDIY Supporter Moderator Joined Jun 4, 2004 Messages 11,886 Location Aarhus, Denmark Nov 25, 2023 #2 Help us a bit more here: What is a T20, why do you want to know. Pic, perhaps? Jakob E.
patrick chen New member Joined Aug 19, 2023 Messages 3 Nov 25, 2023 #3 Neumann T20 Attachments Neumann T20.jpg 131.9 KB · Views: 0
gyraf Well-known member Staff member GDIY Supporter Moderator Joined Jun 4, 2004 Messages 11,886 Location Aarhus, Denmark Nov 25, 2023 #4 aah, the transformer.. It says it all on the markings: A= Anfang (beginning of coil), E= Ende (end of coil) - P= Primär (Primary) - S1, S2= Secundär (two Secondaries)
rock soderstrom Tour de France Joined Oct 14, 2009 Messages 3,577 Location Berlin Nov 25, 2023 #5 gyraf said: aah, the transformer.. It says it all on the markings: A= Anfang (beginning of coil), E= Ende (end of coil) - P= Primär (Primary) - S1, S2= Secundär (two Secondaries) Click to expand... That’s right Measure the resistance of the coils and post it. This can give you a vague idea what this transformer is designed for.
M Murdock Well-known member Joined Jan 28, 2015 Messages 859 Location Germany Nov 26, 2023 #7 Pretty sure it’s a 1:1 transformer. I believe 600:600. I will check the data I have.
M Murdock Well-known member Joined Jan 28, 2015 Messages 859 Location Germany Nov 26, 2023 #8 Had only data for the BT20. But I believe that these are the same. Attachments Haufe BT20.png 596.9 KB · Views: 0
