Sidebstudio
I started this thread because I bought an used (broken) Neumann tlm103 capsule from eBay in order to reskin and put in a mic.
From the photos the membrane was damaged and has the center screw missing.
After having dismantle yesterday I discovered that someone lost the spacing between membrane and backplate.
Some of you probably know that in Neumann tlm103 capsules are glued into front plastic ring.
I made this “dummy” mistake waiting a lot of time before putting my hands on it…
With the spacer I can repair it, without is useless.
Anyone can point me in right direction about the spacer thickness and an idea of how I can make one in an elegant way?
However I don’t want to post the name of the seller on eBay but be aware from a seller from Romania that sell Neumann capsules and watches…
I attached photos of the Neumann capsule and a photo of a spacer inside another Chinese capsule (diameters are different so I can’t use one of them into Neumann).
