Neumann UM57 - broken grille repair
MS Vienna
Vienna, AUSTRIA
Hello,
some time ago the owner of a damaged Neumann/Gefell UM57 approached me, asking if I could repair his mic.
The grille had been ripped off and an unsuccessful repair attempt already performed. So I gave it a go and tried my best.
First I cleaned up the mess to get a good fresh metal surface. I then used solder paste to attach the grille to the base ring.  After finishing it seemed to be a good and stable solder joint and the mic was back in working order. That was already some years ago and it seems to hold up well.
I just stumbled across the pictures and thought I´d post it here.
Happy weekend!
    1.4 MB
Great work!
Two questions :)
How did you cleaned up the mess?
What solder paste did you used?
As far as I remember I used steel wool and sandpaper on the mesh, then put it in the ultrasonic cleaner, then etched away remaining oxides with acid.
I cleaned up the base ring on the lathe.  I was very careful to take off just as much material as necessary. I cut in way less than 0,1mm into the ring´s material for sure - just in case it looks alarming in the picture.
I used  soft-solder paste by Rothenberger.
While searching for SM204 pictures for another thread I came across these. Thought I just throw them in here.
Again not one of my UM57 but from an unlucky friend. Obviously it received a  sustantial bang and I was asked to bring it back in shape. Not too hard to do in this case.
    660.4 KB
