ToroRojo
Thomas' heatsink doesn't electrically connect the cans. Plastic screws are used, and there is a layer of insulation (little square thingy in the picture) between the can shrouds and the headsink.
In regards to the potentiometer solution, aren't the milled pieces too large for one of the switches?
Also, since I have access to a drill press, but not a milling machine, what is your opinion of drilling into the shaft out of some 6mm for the 3.2mm rods? One hole along the axis, for the rod to slide into, and another (tapped) hole along the radius for the set screw. It seems that would work as well...
