rascalseven
I suggest you try the gain structure I posted earlier. Most of the time you won't be requiring higher gains, and so the sound will be pretty much what one would get from any class-A Neve at 50dB or below. As for the higher settings, the second stage does get kicked up a bit, so it shares the burden some rather than placing all the extra gain on the front end. Also a 2x6 Lorlin (or an Alpha from Mouser) is much cheaper than a 3-pole switch, and the input 'pad' eliminates the need for a separate fader.
It's simple, cheap, and sounds great.
Another option would be to build a combination of the SimpleMod and HotRodMod by using the input pad pot from the SimpleMod, and then just use a 1x12 Lorlin (set to six positions) for the six gain settings on the preamp stage. This dumps all the gain on 1st stage, but if you not gonna be using higher gains much, then perhaps that's cool overall. The input pot again eliminates the need for a separate fader, and then you can use the 1-pole switch (in fact, you could calculate resistors to create 2.5dB steps instead of 5dB steps and go ahead an use all 12 positions of Lorlin switch for finer control....?)
I built the SimpleMod first, and it was great (that's my quote on Joe's schematics page). After that I altered the design to the one in my previous post to make it more flexible and to get more gain while still sounding good. The SimpleMod, however, does sound fantastic, and is the simplest Neve-type design I've seen, so I highly recommend it as a first Neve project.
I think you would find any of these options would result in excellent-sounding, useful preamps. Just make sure you check the threads about proper grounding and shielding of old Neve's to help you get the best results with whichever design you choose.
JC
JC
