mitsos
- Joined
- May 4, 2007
- Messages
- 2,886
Hey Martin,
Just got one channel of these together. I'm using Altran in/out, 1+1:4 on in (used 1:2), and their C4000 gapped trafo on output. Sounds great.... except:
I get some weird oscillations at high gain, usually only at max but sometimes in the setting just before. I measured DC and transistor voltages and everything is normal until the oscillation happens. At that point, DC is normal, and TR 4, 5 and 6 all have normal voltages. TR 1, 2, 3 all read strange voltages:
These are C - B - E
TR1 4.0 - 0.6 - 0.4
TR2 22.7 - 4.0 - 7.0
TR3 20.6 - 6.7 - 6.2
So something is going on in the output stage? I noticed that once the oscillation starts, it continues even after I turn the gain down. At first the only way to get the pre working again would be to turn the power off and on again. But after a couple of these cycles, I noticed that if, after turning the gain down, if I waited a bit and/or tapped the mic a bit hard (SM58 in this case) the signal would come back. Should I be looking at the gain resistors or in the output stage itself?
thanks!
These are C - B - E
TR1 4.0 - 0.6 - 0.4
thanks!
