Neve 1290 Questions - Vintage Design
Duka
Your box looks mighty fine.
Its strange that you are getting hum on one channel. My version has no noticeable hum on either channel.
Looking at your pictures, I would have swapped the position of the mains transformer & PSU board. This would have got the transformer slightly further away from the audio stuff. The position of the transformer is more likely to give you a problem like this than where the PSU board is placed.
[quote author="Rob Flinn"]Duka
Looking at your pictures, I would have swapped the position of the mains transformer & PSU board. This would have got the transformer slightly further away from the audio stuff. The position of the transformer is more likely to give you a problem like this than where the PSU board is placed.[/quote]
Yes when I move transformer I lost hum, but I cant locate it on the other place.
Duka
Very nice!
Put the transformer in a separate box outside the unit? Or shield it very well!
For bias I think 80-81mA through the primary windings is fine.
[quote author="Tekay"]Very nice!
For bias I think 80-81mA through the primary windings is fine.[/quote]
Thanks Thomas
If I understand to measure 80-81mA through of output transformer primary. Can I desolder one wire from primary and put meter in series?
Control on zero, no signal :?: :?: :?:
Wow,
I've been away from this thread for a little while.....
Duka that is really a great studio rack piece now. splendid work.
Duka,
I think CJ suggested (or was it PRR?) to put a tuna can around toroid.
You saw this i bet. Works very well... cut a small slot for wires.
Also must clean it thoroughly... like soak overnight in dish soap.
