What would you test with the scope?wish i had taken notes when i calibrated mine because i could offer some real insight, but if you hook up your osciliscope and multimeter, it will start to make sense with a bit of trial and error
The release switch should have no bearing on whether the unit passes a signal if it wired up correctly. If you look at the attached diagram it will probably help you figure out how it's connected.Fellows, can you please help me with the wiring? I am not sure if the Rotary switch for release control should go to point V from the 470k...I am attaching drawing of my understanding of the expected wiring.Any ideas will help me a lot.Excuse my bad drawing.If this is the proper wiring then I will search for the problem of not passing any signal somewhere else(check for soldering errors although the board is fairly simple)View attachment 95867
Thanks a lot Rob! I"ve found my error and managed to make it work!The release switch should have no bearing on whether the unit passes a signal if it wired up correctly. If you look at the attached diagram it will probably help you figure out how it's connected.
Wow! Can we see some photos of what it looks like inside?wow nice chaps around here indeed!
just found an early 70's Era RM58 ..untouched. thinking about which direction to head down, if any. it's completely original. no serial numbers. first we see if she's working eh? will be checking in here in the future. you guys are an amazing resource. thanks in advance!!!
Register today and take advantage of membership benefits.
