Svart
Since I'm out of work for a little while I have decided to work on a project that will hopefully be a basis for an audio design company, a proposed collaboration between myself and another forum member. Since this *might* be commercial( but low volume) I'll understand if you don't want to give free information. I'm just interested in what other designers would want since I know you guys would just dig right into the box to see how it ticks, i'd rather give you something that you'd rather NOT mod but would enjoy as is.
First question: If you had to choose between a power transformer and an offline switching power supply which would you choose? Why?
2: I need a standby power source for a circuit that needs to be powered regardless of the main power being on/off. I have the choice of another offline switcher which needs an inductor and schottky diode, or I can use a diode/R/C/zener regulator which would need at least a 1w resistor.
3: Audio switching. Relays or FETs for switching? Done properly FETs are still a bit cheaper than relays since Relays need the FETs/freewheeldiodes also, but FETs give an ever-so-slight distortion. What about Audio POWER switching?
