jilski
Member
- Joined
- Sep 16, 2015
- Messages
- 22
Hey DIYers,
I am new to this forum and pretty new to analog electronics, although I do audio programming as day job. I would like to build a simple state variable filter (variable f, Q and choice of LP/BP/HP), which goes into a soft clipper using diodes and came up with the following schematic.
I took the components mostly from the ESP pages and the filter itself works on breadboard. My question is, did I do the right thing interconnecting those components? filter -> clipper using a 3 way switch and then a buffer before the final audio output? Also, did I do the bypass switching correctly?
The power supply is from the "Joe Cheep" compressor schematic so I guess it won't need commentary.
I would greatly appreciate a quick look and comments. This is just one channel of a two-channel version, but the other channel is completely separate and otherwise identical.
