G
Guest
Guest
Hi folks,
This might be a simple question. It may not be. It might be a dumb question.
Anyway:
People talk about capacitors in the audio path. I'm just wondering how you actually trace the audio path in a mic pre.
I'm asking specifically because, after shorting a power supply, the fine gain adjustment (on my 7th circle n72) isn't providing the specified adjustment of 6dB of gain. That pot is just a three terminal resistor, and I'm wondering how pressing this is (on the list of things to worry about). I mean, I'm getting the same gain as before and it still sounds great across the frequency range, but I'm wondering if such an issue is affecting the fidelity in some sort of subtle way.
Simply put, if I'm just losing some of that adjustment, I'm going to put it at the end of the line. If it could be affecting frequency response or bias or something, I'll probably dig a little deeper.
Thanks...any input is greatly appreiated. Here's a link to the i/o schematic for the pre: http://www.seventhcirclestudios.com/SCA/N72/docs/10.pdf
It's Friday,
Kelly
Anyway:
It's Friday,
Kelly
