Hi all,
We have had an SMC-2B at my work for many many years which sounds phenomenal… when it is behaving properly, which is usually isn’t.
For the past several years, we have encountered noise issues with ONE channel on the unit and as of right now it’s totally unusable. Hiss, crackles, pops, always a little different
last year, I went through with the guidance of Tube Tech via email and blindly replaced a number of parts they told me to replace. They wouldn’t share a schematic or any service docs with me (which I understand why!) so we went back and forth replacing random parts around the summing amplifier until the noise issue (sort of) went away. I figured out some parts based on PCB traces but obviously not how they work within the circuit, which wasn’t very helpful.
after fixing this up, the unit would just randomly blow fuses. I replaced the bridge rectifiers within the units as they looked super toasty and even started running the unit with a bucking transformer to drop our wall voltage from 125vac~ to 113~115vac. I had replaced the PSU electrolytic caps the first time I serviced it (when I was trying to solve the noise issue) because several had developed bulges. Replaced PSU dropping resistors as well. Fuses stopped blowing after this and the unit behaved fine for almost one year.
At some point, a different tech worked on the unit, repairing some burnt traces on the underside and likely a different OT on one channel. I have to take the unit apart again to double check but if I remember correctly, the channel with the noise is the same one the previous tech worked on
this is a really phenomenal sounding unit but the fact that it is so unstable is really sad for us. Hopefully our unit isn’t completely cursed and can be remedied.
to cut to the point: does anyone have a schem for me to reference or has had similar problems with this piece?
