NTP 179 120 Alternat plug does it tells something to someone
Nobru
Paris
Hello DIY'ers,
If you read the post regarding the ntp179120 you know the "plug problem" I am facing.
After cupple hours of reflexion I arrived to this result if I want to use the179 120 in stereo mode without linking a second unit (that's to me quadra type of thingy).
Taking the pin connection info available at gyraf .
Left channel (+) would go on the Pin DC Free input
Right channel (+) would go on the pin Direct input
Right and left - pol would go together on the Input ref (com)
That's for the inputs.
Left (+)out would go on the pin DC Free output
Right(+) out would go on the pin Direct outout put
Left and Right - pol would go on the pin -vb 0v.
Could it be output ref instead? even with that +12 V around? seems od to me but maybe somebody has an explaination for me.
THAK YOU FOR YOUR POST!
B :wink:
BUMP BUMP!
Output l/r pol- on the 0 volts not VB 0.
BUMP BUMP
Anybody know about that?
Thanks.
