whiskeynipple0088
Active member
Hi All and thanks!
yup Im late as hell to this party!
Sorta a newbee but have repaired many electronics (tv, refrigerator, dryer, mixer, A/D converter etc.... I can solder)
I can repair alot of electronics but and just starting to understand what each componant does (thanks Ethan Winner for his Hardware Tutor).
Please forgive me, I know this topic exists and I saw alot of disscussion, but alot (and I mean a lot,... all Prodigy Pro) links are dead.
Ive seen the work by Vintage maker, Volker, Crostov, Studio B and Holger...... I want in. (man what I wouldnt give for a diagram or schematic of some of those extra controls like centering or gain - meters... oh my. or the pcb Holger has at the dsub connection)
I have been educating myself on the subject and I know someone has done something nearly (Holger, Studio B) identical to what I want to do.
After reading too many threads I think I have confused myself. It seemed much more clear reading NYD, Fred Forssel and Ethan Winner info....... (yeah I know ,... why dont you just do that then!)
Also looking for where things go in the signal chain.
I will only be using 4 stereo outputs from my daw for now - so I need to be able to change the gain (I think) when I add more and more outputs from my daw.
what I would like to build: Summing amp.
16 (or just 8...) Stereo inputs (all with center switch or not since I have 4 mono)
4 Mono (centered) inputs
2 Send /Return (not sure if that should be before or after the amp)
1 (do I need?.... I would like) Gain
can I get multiple outputs directly from the amp? (if not Ill use a re-amp in another box)
the other box Id like to build: dont know the proper name for it BOX (this would go after the summing amp - believe I will need a re-amp for this)
3 inputs - selectable by switch
2 (stereo) meters
3 Monitor outputs - selectable by switch
2 Headphone outputs - with gain knob
2 Record outputs
1 talkback mic - direct to headphone only, with gain knob
the second box is not priority at this moment
I ordered Model: 10657 V475-2
If you know a link to a good 'heres step by step what I did' link, please pass it on.
thanks again and great work out there guys
chris
2 (stereo) meters
2 Record outputs
chris
