TillM
Do you measure in AC?
An measure between green and green and yellow wire with yellow wire ?
By the way.
I also build a second one.
My second mic has nearly 6db lower output then the other one.
But it sounds good like the other.
Is it normal and I can brief it as tolerance ?
Edit: Found the fault, one screw from the backplate was not tighten enough. Now they are nearly the same level.
By the way.
