HellfireStudios
My 251 schematic shows 1000pF for C5. Though, it would be interesting to hear what a smaller value cap would do to sweeten the top end in the C12 circuit...
-James-
-James-
Melodeath00 said:Thanks, micaddict - I've read that post many, many times myself through various google searches haha.
What is interesting/odd is the talk on PRW about how the decaying plastic int he 251 affects the tone. I wonder if anyone can chime in as to how that would be possible.
Matador, are you outlining the mod just so people know, or does this mean there will be no formal/official 251 PCB and build thread? I almost "assumed" it was coming, since it seems like as soon as I registered on this site, slowly but surely a PCB for the U67, M49, M269, and C12 was released.![]()
Tim Campbell said:Dear Jess,
Yes, you tie the backplates together. If you get no signal something is very wrong. Did you try the mic with the other capsule?
You must be very gentle when soldering the solder tags. All these screws thread into plastic. If they are over heated at all the screws can become loose. Check that the screws are snug (but don't overtighten them).
Scroll through the pattern selector and see if you get any signal in omni or figure 8.
If you can hear the amplifier then you have a missing connection rather than a short. A picture might help.
chunger said:Did you verify prior to connecting Tim's capsule that the B+ voltage absolutely did not exceed 120V? When I installed my non-expendable capsule, I adjusted B+ well to the low end of the trimmer pot's range and slowly inched it up after the capsule was installed.
Melodeath00 said:Those are good points. I don't feel the switch is particularly important, since we are using non-replica mic bodies anyway. I guess it would only matter if the switch caused a difference in sound compared to the 9 pattern PSU. "The 251 pattern control is achieved by manipulating backplates in the capsule, with no voltages exceeding 60v, and the C12 varies the voltage from 0-120v on the rear membrane." I'm not experienced enough to even make a guess if there COULD be a difference in how the capsule reacts in those two different situations.
JessJackson said:Tim Campbell said:Dear Jess,
Thanks Tim,
I just checked all continuity, Everything is fine. When soldering the capsule I was very quick and made great connections.
Although one thing i just noticed. On the schematic ( http://musicalsparks.com/images/c12/c12_schematics_v3.pdf )
It shows Front Capsule going to R16 (30M) and Rear Capsule going to GRND
On my circuit board RC PIN goes to R16 and FC seems to be on grnd. although this would just reverse the capsule.
I found that i had accidently r17 and r13 swapped values, so i switched them just now. about to try it.
HellfireStudios said:I know it is probably nuts, but I tend to put heat sensitive components (especially germanium diodes) in the fridge for an hour or two before I heat-sink-clip, and solder them. It's like insurance.
-James-
MicDaddy said:Are there any negative ramifications from such a temperature swing? I don't know just posing the question.
