pmcorbett said:... are there different functioning parameters (metering, voltages...etc) I should be aware of when testing and tuning the mic? Let me know when you can. Thanks!
drumminkiger said:Well, I pulled the trigger today and bought all the remaining kit components to make my c12 clones after sitting on my mic bodies and tim's capsules for about 6 months now. The only thing I have left to buy is the tubes. I emailed Christian at pro audio tubes, and he recommended two tubes to me. One of them is a vintage GE and the other is a vintage mullard. He said the GE seems to be the choice tube for most folks, but he said the mullard had a more defined mid prescense and is also about half the price. I'm just curious if anyone has tried the mullard, I'm even somewhat curious if it kinda tilts the mic more towards a 251 response. It might be kinda cool, what do you guys think? Anyone tried it?
drumminkiger said:Yes, I would be buying a matched pair of tubes, so one kind or the other.
Matador said:JessJackson said:hi matador, i have the dale 100k resistor there
i have ddm oscilloscope and sine wave gen
Ok, let's try this: disconnect the capsule lead connected to FB (the one that leads to C13). Inject a ground-referenced 1V peak-to-peak sine wave into this node (right at the teflon standoff labeled "FB"). Then read the peak-to-peak voltage coming out of the XLR jack that goes to your preamp.
You should be about 5-6dB of gain through the entire chain to the output jack. If the signal is way low, move the injection point right to the tube grid (pin2 or pin7 depending on which half of the tube you picked).
Let's start there and we'll debug from there.
Tim Campbell said:Disconnect the mic from audio, remove the headbasket and turn on the mic while looking at the membrane. Is it collapsing? Try the mic with the original capsule. If the problem disappears then it is the capsule. I have never heard of this problem with one of my capsules but there's always a first time.
tonycamp said:Gotchya, i got the 6072 $100+ ge from christian, it keeps sounding better and better, this mic is real impressive. As a matter of fact, i can't believe how great the matachung c12 and the ioaudio Mk47 sound! Both these mics are quite literally a dream come true for me ;D
jrmintz said:Matador, is there any reason I can't mount the board to the underside of the rails rather than the top? I'm using a fatter output cap and I might need more room for clearance. I was thinking about mounting in the center of the rails using nuts as standoffs.
