chunger said:Can someone confirm if the Carvin has a compatible psu? I direct people to the Apex 460 because I know almost for certain that it comes from the same factory, but the Carvin unit has the tell-tale sign of being supplied by a different factory than Alctron (the dark red plastic pieces holding the tube as opposed to orange). I am nearly certain I know who makes this mic and the psu should be just fine, but I'd really like to see a photo verification before directing customers who are needing to build immediately to the Carvin product as a suitable donor.
Matador built a prototype on an Apex 460, so we know for sure that one is good to go as a donor.
JessJackson said:I edited your schematic to what I understand is the 251 modification. let me know if this is correct.
jrmintz said:Just did a three-way test recording a 1965 Gibson Hummingbird with my C-12 clone, a KM-84, and a KM-56. Used a Daking preamp and LA-2A. They sound remarkably similar, but I think I preferred my C-12. Thanks, guys!
jrmintz said:When I first built the kit I did the 251 mods. The mic hissed and spit. I undid the mods and put it stock and it was fine. So I redid the mods and it was hissing and spitting again, so undid the mods again and now it's dead. Could the hissing and spitting have trashed the tube? Everything seems to be working okay, voltages are all right on, just no sound. It's possible I screwed up the capsule, I suppose, though I don't think so.
I had disconnected one backplate by accident. It's working now, though why it was unhappy with the 251 mods I don't know. There's also something weird going on between pro tools and my patch bay. I think it's time to take a nap....
Mr. Warshaw writes:
The Telefunken ELA M 250/251 was made for Telefunken by AKG after Neumann discontinued its OEM production of the Telefunken U 47. Of course Neumann still made the U 47 for many years. Telefunken needed a quality condenser, and AKG stepped in.
The differences between the C 12 and the ELA M 250 are small but important. The C 12 is remotely controlled for pattern by polarizing the rear diaphragm with a separate variable voltage from the power supply, while the ELA M 250/251 has switches in the capsule assembly that change its polarization pattern. The 250 has two patterns, Omni and Cardioid. The 251 included these patterns and also the figure eight.
The second difference is in the circuit. The C 12 and ELA M 250 circuits are similar but not identical. They both use the CK 12 capsule, T/14 transformer and either the 6072A tube (US version) or the AC701 (Europe), but the grid coupling, cathode bias and capsule polarization are different.
Third, the body style of the C 12 and ELA M 250 are not the same. Most important, the head grilles are different, so acoustics are also different.
JessJackson said:lol, what exactly were your 251 mods? what values etc..
How did you guarantee that the tube boas voltage (sent through the cable and attaches to the "P4" node at the base of the mike) was forced to be ground? Did you ground it in the mike? At the PSU?
jrmintz said:I'm kind of liking the mic the way it is - I think I might wait for the dedicated 251 kit.
tonycamp said:jrmintz said:I'm kind of liking the mic the way it is - I think I might wait for the dedicated 251 kit.
Hey!!! did i miss something??? Is there a ELA M251 kit in the works?
I'm with you mintz, I modded up my head basket acoustics a bit, it may not sound exactly like a C12(i wouldn't know, cause i've never worked with the real deal in person), but it sounds as nice as any mic i've ever worked with!!!
