chunger
The recommendation to glue along the edge of the mesh where it meets the base plate is good. The next production batch of headbaskets will be glued at the factory to eliminatebthe resonance.
I actually obtained this particular emblem from a knife set. It was attached to the knife caddy. I've been on the lookout for badges ever since I started modifying and building my own mics. Surplus military medals, metal clothing/craft buttons, and even the gems off of a vodka bottle have served me well as mic badges.Toure14 said:HellfireStudios said:I used Loctite Go2 Glue on my single layer headbasket from Chunger, and it did the trick. Check out my earlier posts on the subject for more details about the glue and how where to apply it. I noticed one person had a hard time finding it. I found it in both Target and Wal-Mart chains (usually in their "hardware" sections).
I realize after reviewing this post that it may look like I own loctite. I am in no way affiliated with them. I just like most of their adhesives.
-James-
BTW, here is the finished mic. Sorry it took so long to get a pic up here.
Where did you get the nice badge made for the mic?
Spencerleehorton said:Hi Matador,
the problem i was having with the low output was the transformer, i changed it and hey presto, im pretty sure all the trimmer pots are correct now, how critical are the 392R resistors? or what part of the circuit would limit the voltage supply to the 100k pot?
regards
Spence.
the mic is working fine now i have changed transformer, getting good signal through it, im just not getting 120v on B+, so i think i need to lower R1, R2, and R4 to raise the voltage.
R1 and R2 are 5k and R4 is 27k so should i replace with R1/R2 = 2k and R4=15k ?
regards
Spence.
