Matador
Spencerleehorton said:Hi Matador,
Im pretty sure i was just looking at the wrong psu schematic and i have 91k in the psu.
what should i lower them too?
regards
Spence.
Aye. The best thing is to lower both R1 and R2 equally. It looks like your tube is drawing a bit more than the expected 0.6mA at idle, so each 10K drop will yield about 50-10V of adjustment. So if you dial R4 to until the B+ is as high as it can go (let's say 100V), then dropping R1 and R2 by 20K each will raise B+ up to about 140V, when you should be able to drop back down to 120V by adjusting R4 again.
I can help you zero in on it a bit better if you max out R4 (drop B+ as low as it will go), and tell me the new B+ voltage with all resistances at maximum.
