clintrubber
Sounds like some weird messing up of signals/cancellations/whatever. Since the actual gain-reduction is this simple, how about trying this:
- Use only the sidechain & the gain-reduction section (= two resistors & the Vactrol IIRIC).
- Drive both the sidechain-input & the gain-reduction section from a known good source with adequate output muscle.
- Probe the signal at the output of the gain-reduction section.
This should work.
If it doesn't then there's something sick in the sidechain (try various pot-settings) or you've been able to develop an error in the three-device gain-reduction section. How sensitive are those Vactrols to soldering heat ? Have you inserted them OK ? Have you inserted them OK ? Have you inserted them OK ? An error here will less easily show up in a DC-voltage test.
Then add the gain-make-up, if it's OK then the input etc.
Good luck,
Peter
This should work.
Good luck,
Peter
