[quote author="FredForssell"]Hey everyone,
The value of the series R working against the minimum on resistance of the LDR determines the maximum amount of gain reduction. I use VTL5C1 optos because a) they have 500 ohm on resistance, and b) because they have as fast an attack time as any opto I have seen (rate at about 1.5 ms).
The value of the series R that I use is 10k which gives a max gain reduction of 20 or about -26 dB. When the cell is completely turned off, I do not want the input impedance of the gain make-up/buffer amp to cause a signal drop across the series R, so I want the input impedance of the buffer amp to be at least 10x the value of the series R... in my example that means 100k. If you can live with some drop across the series R you can make the buffer input impedance smaller.
All of this brings up another point in choosing an opamp for your gain make-up/buffer amp. When the cell is off, the source impedance (seen from the input of the buffer looking back into the series R) is at least the value of the series R, or in this example at least 10k. So I'd recommend using a opamp with a JFET input stage, like our (gee, surprise) JFET-992/993 opamps, or any good low noise IC opamp with a JFET input stage.
[/quote]
What does he mean by "When the cell is completely turned off"?
I know what loading sounds like (like on a FUZZ FACE guitar pedal)
I don't think this would be THAT extreme but I feel like I'm hearing something... especially when compressing.
That's why I'm focusing on Fred's comment above & JFET/loading.
The only other BS I'd like to take care of is the ATTACK & RELEASE control... you can hardly turn them without being drastic. :roll:
I think a LOG taper would better suit, maybe. It would be nice if other builders of this thing could chime in. :green:
